Gingerbread Phone Call Problem(s)
OregonYankee
I downloaded and successfully installed 2.3.3 on by X. All is fine except for one small and one large problem - both relating to incoming phone calls.
Small problem: when a call comes in, the lock screen appears. I have to unlock to answer. This was not present in Froyo; I can't find any way to go directly to the answer/ignore slider.
LARGE problem: I answer the call. Fine. But as soon as I do, my music player starts. Not fine. Now I (and the caller) are both listening to music other as well each other. :-\ I am using the stock player. (XiiaLite was also starting but I think I've solved that.) Any thoughts on how to stop the music and take the call??
Wow, first I heard of that one. What build did you install and did you do a factory reset?
I'm running GB rooted as well and have run into a few little quirks as well, usually just do a reboot and it gets better....
Something is clearly wrong with your install. Do it again and wipe data and cache after flashing.
...unsupported versions of Android OS are ALWAYS supported on Android Central. :)
ecomranx05
