go launcher and battery drain
cdaff62
6
Hello all i am using a samsung mezmerise and i need to see if anyone can help me please . I have been watching my battery and it says that the screen is using most of my battery how do i fix this . I have it sat it to lowest brightness and also time out to 1 minute but the battery still says the screen usage is like 70 percent can i lower this and how. This is with go launcher could that be the problem .also have home switcher and when i try to seitch back to the one tha came with the phone it force closes .
That is normal. Even on my rooted fascinate it is 65%. The system battery log does not give a very detailed picture of actual battery use. To get a better feel for the apps and processes using your battery try SystemPannel to track app battery use.
https://market.android.com/details?id=nextapp.systempanel.r1
Also, there is a good thread in the Fascinate forums talking about how to extend battery life.
http://forum.androidcentral.com/ver...8399-how-discussion-improve-battery-life.html
Finally, Go launcher uses very little battery. I find it actually uses less battery than stock Touchwiz.
Since it has a Super AMOLED screen, ensure you have a dark (a lot of black if possible) wallpaper. Lighter colors, especially white, will consume more power.
ok thank you all so much for the quick reply will try system panel and will try a darker wallpaper
alkarastone
