GO Launcher problem?
pegleg#AC
Active member
Apr 29, 2010
28
I love the size of the OG Tab I have had since last spring and for the most part it has worked well. Twice in the last month or so I have had to do the dreaded factory reset. The first time it was randomly (and constantly)rebooting while in the middle of using it. After the reset it worked flawlessly for about a week,until I reloaded GO Launcher. After a couple of days of use with no problems the unit had extreme battery loss and wouldn't take a charge. I thought for sure it was time to replace it,but figured I would try one last reset. Now two weeks later its still running perfect, but I really don't like Samsung's launcher and I'm afraid to load any of the popular launchers and create any more problems. Any ideas? Thanks
vigorific
