Going from EA28 stock to EB01 leak
tiger1234
6
How's everyone?
I am a noob and new here so please hear me out
I am planning to install EB01 on my unrooted fully stock EA28 Fascinate
I was going to follow DroidXcon's thread "[Odin] Full EB01 Froyo leak, packaged ROMs w/root and new clockwork **UPDATED**2/12
Do I have to go back to DL09 and then work my way up
or can I go straight from stock EA28 to EB01?
AND in case something goes wrong or I want to get OTA from verizon do I just odin back to DL09?
Please help:):)
DroidXcon
11,100
3,392
How's everyone?
Please help:):)
you can go straight in ,,,,,,and yes most likely will need to go back to DL09
Landshark
4,434
1,382
113
Im wondering about doing this too... how does it WORK? Does it void a warranty?!
The verizon rules say it voids your warranty. But there is a thread in the ROMs/Hacking/Rooting section that have instructions and all you need to get back to a stock build should you need to return your phone or anything like that.
Landshark
4,434
1,382
113
Just go into the Rooting/ROMs/Hacks section and start reading the threads starting with the all about rooting, then the EB01 FAQ's thread. If that all makes sense after you read it check out these three threads and see if one of them would work best for you:
http://forum.androidcentral.com/ver...roms-w-root-new-clockwork-updated-2-12-a.html
http://forum.androidcentral.com/ver...om-dl09-super-clean-0-4-eb01-2-2-updated.html
http://forum.androidcentral.com/ver...acks/59339-release-eb01-rom-kernel-radio.html
willenium_1217
163
5
You don't need to flash back to DL09. I was on EA28 and flashed straight to EB01 and it worked beautifully. If something is to happen, an easy flash to stock DL09 will be easy enough to do. I am so grateful to DroidXCon for their work and Adrenlyne as well.
sdog21
22
Noob Question. Think i know the answer from reading in the forums, but would like a confirmation.
I have EA28. If i flash to EB01, and then want to return to stock, I would Flash with a DL09 ROM (cant seem to find an EA28 ROM), then use the OTA on the phone to get back to EA28? Can someone confirm???? THANKS!!!
DroidXcon
11,100
3,392
yes this should work, even flashing DI01 would work
krumplycelloids
