please don't look for any non-obvious defects. we have too many people inspecting with microscopes that give the nexus too much hate that it deserves. your screen is not gonna pop out on you so just enjoy this amazing device and spread the word
hey all ive seen multiple thread with people complaining of dead pixels ....and i think screen lift? what is that exactly?
what else should i be on the lookout for and pay close attention too? thanks
Most of the tools you'll need to properly check for defects are available on Harbor Freight.
#1. Precision machinist's micrometer ($62). Be sure and check all the way around the entire exterior edge at increments no more than 1/100 inch apart. Note all measurements. If the largest measurement is more than 1/1000 inch higher than the lowest measurement, IMMEDIATELY return the device. You could have screen lifting (or a hair).
#2. Precision level, machinist specialty ($45). Place N7 on a level surface. Be absolutely SURE that is level by pre-leveling using a larger precision level to check absolute flatness of the surface using Harbor Freight Precision Contractor and Engineering Level ($142). After proper leveling of initial test surface, make sure that N7 is at room temperature (Harbor Freight precision infrared remote temperature sensor ($89). Temperature of N7 should be within .0007 degrees (F) of room temperature in your home measure at no less than 12 spots in your home, no less than 12 feet apart. In mama's basement, you may measure 4 positions 3 times. Place precision machinist level on surface of N7, and take readings at 1 degree increments for the full 360 degrees rotation of the device. If readings vary more than 2 degrees in any TWO segments, return the device immediately!
#3. Obtain a portable UV LED light from Amazon (sorry, Harbor Freight doesn't have these, but they're cheap from Amazon anyway) $29.95 with free shipping for Prime members! Cool N7 to precisely 41.7 degrees (F) by hosing it down with a can of Dust Off held upside down and allowing the propellant to cool the device, and measuring with Harbor Freight Infra-Red precision remote thermometer. Turn off all room lights (yes, even the lava lamps!), and throw the cat out of the room (they have high body heat). Immediately turn on the UV light from Amazon and check for any inconsistencies in the fluoresced patterns/colours. If you see ANY difference at all, IMMEDIATELY return to Google and request a replacement.
If you do receive a replacement from Google, IMMEDIATELY execute all of the above approved tests, exactly as before (you already have the tools now) and return again if there are any variations on supplied test datum. Do this until a unit (preferably one with a C120 serial# precedent) passes all tests. Then you may load up apps, enjoy it, and then blow it up by rooting it and beg for help with your now bricked N7.
Orrrr, you could just do as JD914 suggested above.
I
Just me or is this whole post a little excessive? I mean, it's a $200/$250 device. Making sure specs are perfect all the way to the thousandths of an inch is absurd. Besides, like I mentioned before for half the price of that micrometer you can get 2 year insurance plus accidental from walmart. Work smarter, not harder.
There is no rear view camera.
