Going to buy g2 case help...?
jeno27
293
I would like to purchase g2 case in Amazon... the case which I choosed... Given as... (case for g2 T mobile and sprint) if I purchase this case.. Will it suitable for my model LG g2-D802....help me to purchase
You should be fine....I think! I was under the impression the Verizon model is really the only one to watch out for....on amazon they usually say if the case will work with verizon, if it doesn't I am sure your ok.
Amazon is pretty good about returns if Amazon is the seller of the item - in case it ends up not fitting. If it's a third party seller, the seller has to approve the return.
Elton
zolepco1
