- Aug 15, 2012
- 24
- 0
- 0
I was having poor battery performance and I figured out why.
I had this app called light flowy or flowy light (can't remember right now). Even though the app was not activated it kept waking up my scree and destroying my battery.
If you have that, turn it off and delete it. The devs have filed a bug with Google as their app performs poorly with ambient display.
Also, I have relay for reddit, an app that when you get a notification and don't answer it, keeps pinging the phone. I changed those settings and my battery is freaking kick ***!
Hope this helps for some of you.
Note: neither of those two apps showed up in any battery log it just said the screen was the issue.
