Google Services Battery/heat issue.
rrballer11
335
I've been having the battery drain issue with the Oneplus 6T. The Google Play Services has been using a tremendous amount of battery usage. I read on a forum that disabling the "Body Senors" would help the battery issue, and it is true it had helped my battery drain issue/heat issue.
This may help anyone with the same problem.
Well, thanks for the suggestion! You mean in the Google Play settings on your phone?
Yes, Go to settings > app & notifications > google play services > permissions> Body Sensors.
Hopefully they fix the issue but as of right now, this is what has worked.
(This could possibly happen)
When you use a location based app it will tell you to turn on locations services most likely, say ok and the body sensors should stay off still.
johanchsirisa
