Got Another Battery For My Note 9...
Climb14er
810
3
18
This one I believe will be the last for this phenomenal phone. It should take me till early next year, when the security updates will probably expire. Don't know what phone to transition to... could be another Sammy, Pixel or heaven forbid, iPhone. Definitely want unlocked, dual/esim phone, and will get OS uodates for at least three years... or more. There are choices... ??? The Note 9 continues to serve me well.
How does it perform with the new battery? I had bought a used Note 9 recently and thought about going this route as well so I could have a brand new battery.
Performs fine! Note 9 is a great phone. Just using it a lot, degrades the battery. Back up to speed nicely.
How much longer? Like a noticeable difference? I recently purchased a refurbished Note 9 from Samsung and though they say they rebuild devices, the battery life doesn't quite seem as good as it should be.
I just got it the other day. Just go in and get a new Sammy battery.
Is there any way to test how badly the battery has degraded vs a new replacement battery? Mine certainly isn't holding up like it used to, but I'd love to be sure the replacement will make the measurable difference I'm imagining... :)
Sonfollower28
