- Mar 12, 2015
- 1
- 0
- 0
My GPS on the S-5 mini is dropping its fix every time I start a navigation app. If I use a simple GPS analysis app, it works fine. Locks and never loses the fix. When I open maps withou navigating anywhere, it also works fine, showing the blue dot and following properly the way as I move. Same with Waze. But when I select a destination and start the navigation, almost instantly the GPS signal is lost. I go back to my analysis program, and as I open it, the GPS signal is recovered. If I don't see the Waze or the Google Maps turn by turn page, the voice instructions will work fine. So, as long as the GPS analysis app is on the screen, the navigation works fine...
I tried to leave it on GPS only, changed it back to high accuracy, tried some apps that forums mentioned that would fix the problem and nothing worked.
Any suggestions? I run on kit-kat 4.4.2
