- Jul 28, 2013
- 9
- 0
- 0
I bought a brand new Nexus 7 (2013) and am having problems with the Satellite GPS. The GPS only works for about 10 minutes or so after first using it. If I swap apps or use another app that uses GPS, my GPS dies (I'm testing using GPS Status with WiFi off).
I have to completely power off the device and power it back on again for it to work once more.
UPDATE 1: I've found that you can go to Settings > Location Access and turn off "Access to my location", wait a minute and turn it back on. Then it seems to work again. However, switching apps, breaks it yet again. Ugh!
UPDATE 2: Above trick on the settings doesn't always work. Sure fire is to reboot.
