My Note 2 is having some bad GPS issues. The GPS works just fine in Maps, but if I try to find my location in Accuweather or Redbox, it doesn't find anything. This phone is brand new and isn't having any other problems. Any advice?
It sounds like theirs nothing wrong with your gps. It sounds like those apps aren't working properly. And I'm sure you're set up to recieve updates for all your apps automatically. So, you could return if you're within your 14 day purchase period. That sounds like your only option but I doubt it would solve your problem with Accuweather and Redbox.
