[GUIDE]Freezing GS3 Bloat with Titanium Backup!
PsYcHoNeWb
1,360
476
As your already are well aware this phone comes with a substantial amount of bloat. Most the stuff I would never use but this will be different for everyone. In order to remove a lot of the bloat of your device you will need to have root access which can be found in another thread or over here....[ROOT] [RECOVERY] SCH-I535 (Verizon Galaxy S III) - Verizon Galaxy S3 Development - RootzWiki
Once you have root to your device you can start nuking your bloat. All you need is Titanium Backup installed. Once you have that installed go to the Backup/Restore tab and you can start freezing. Click on the app, and the popup will come up with the option to Freeze. That simple.
Whats the big deal with bloat? It takes up RAM... A LOT OF RAM. If you don't believe me, go to your task manager and view your RAM usage. Clear your RAM and look at the number. Once you look at that, look at my RAM numbers after a clear. They are better and they much better after it has been running for a while. After having the phone unplugged and running for a good 17 hours my RAM was only at .90 GB consumed.
attachment.php
Here is a running list of what I have frozen on my device and it is running fine.
  • AllShare Controller 1.0
  • AllShare Play 1.0.0210
  • AllShare Service 1.0
  • Apps 3.05.78
  • Backup Assistant Plus 1.0
  • Backup Assistant Plus 2.0
  • Color 1.1.5.23
  • Exchange Services 3.1
  • Face Unlock 4.0.4-338691
  • FWUpgrade 1.2.0
  • Guided Tours 1.1
  • Kies air 2.1.205131
  • Kies via Wi-Fi 2.0.0
  • MAPServiceSamsung 4.0.4-I535VRALF2
  • Media Hub 1.6.0(LE07, 6487)
  • Mobile Print 1.6.0.1219
  • Music Hub 0.0.0.01
  • My Files 1.0.0
  • My Verizon Mobile 10.0.229
  • My Verizon profile 0.2
  • Nearby Devices 1.3.0
  • News Daemon(EUR) 120502.01
  • Polaris Viewer 4.0.4.0.4024.26
  • S Suggest 3.1.69
  • S Voice 4.0
  • Samsung Account 1.2.051
  • Samsung Backup Provider 1.0
  • Samsung Cloud Data Relay 1.1.8
  • Samsung Cloud Syncadapters 1.0
  • Setup Wizard 1.0
  • SNS 1.01
  • Stock Daemon(EUR) 120503.01
  • Sync Service 2.8.0.1.17
  • TalkBack 3.0.2
  • V CAST Tones 4.5.17-3
  • VPN Clinet 2.5.1
  • VZ Navigator 7.5.1.115
  • wssyncmlnps 2.0.0
  • Yahoo! Finance 120510.01
  • Yahoo! News 12.05.04.01
Pretty long list isn't it? I am sure there are some more that I could freeze but these are the ones that I have been playing with for now and if I find that some cause issues or there are others that can be frozen I'll update.
I highly recommend that you be very careful with removing your bloat from your phone. Some of the apps that are frozen above you might use and freezing them will cause you to loose them for use. If you find that you lost a function or app that you like to use, just go and unfreeze it. All of the sync services that I have disabled are either Verizon or Samsung. I never disable anything that looks like a Google function to make sure I keep stability.
Do this at your own risk, I take no responsibility if you have problems with your device after freezing your applications. I recommend that you be very careful with freezing anything. If its in question, don't freeze it with a bunch of others. Freeze it by it self, and make sure that it doesn't cause device instability.
Any questions feel free to ask.
Thank you very much for the list. I just got my SGS3 yesterday and rooted today. One of the first things I always look for after rooting is a list such as this. I just so happen not to use anything on the list so glad to have them out of service so that it saves battery and memory. Again, many thanks for this list!
Just a heads up: if you use a Bluetooth headset in the car, don't disable s voice. You won't be able to voice dial. Mine tends to crash twice before it works anyway, but ymmv.
Sent from my Galaxy S III via Tapatalk
Thanks for the list. However I do see you freezing a lot of perfectly good apps that aren't bloat.
Bloat is considered anything over the stock Google apps that comes with the phone, or at least in my opinion. The bloat is in there but I also froze other apps that Samsung threw on the device that I know I would never want/use. If you don't want to freeze those you don't have too, your choice. Everyone will use their phone differently and because of that people will want to get rid of or keep certain things.
is locking an app the same as freezing it? if not what is the difference
What do you mean locking an app? I don't see that on TitB, unless I am missing it.
Freezing apps will basically stop it from running on your device, doesn't delete it off your phone but will basically force stop it and never allow it to run until you unfreeze it.
What is "bloat"? Any app you (the user) don't want on your phone.
What's bloat to me may be an essential app to you.
Personally, I'd like to see ROM developers (including VZW developers!) not include ANY app that's available on Google. I'll pick and chose my own, thanks!
while im excited to do this im bummed that there is not a 'free' version that will freeze apps. Pay app I guess is worth it for this sorta thing.
Titanium Backup is worth the money, believe me. I have had it since my Thunderbolt and haven't had a complaint at all. Makes flashing ROMs a lot easier if market restore doesn't work.
If I am not rooted, is disabling the bloat the same as freezing them (rooted)?
FWIW, for lists like these, I like to see a complete list of apps that are *safe* to freeze. Therefore, a longer list with apps that some people may want to leave active is fine. If a person wants to use an app, they are free to leave it unfrozen. The important thing is to have a list of apps that are know to not cause system instability when frozen.
Also, just fyi, you can freeze:
Weather 120605.02
Weather Daemon 120426.01
Weather Main 120605.02
-Suntan
I wonder if you have Google Now installed if that would replace the S Voice?
I am not sure how much Titanium is now a days but I have had it for a while and it is well worth the few pennies it cost.
I remember seeing a cartoon a while back, some guy was buying a cup of coffee at for $5.50, a few gallons of gas for $20, and a few other small wasteful purchases for a few dollars but then later in the day he was sweating bullets over paying 99 cents for some app. I guess we are so used to free, a few bucks seems like a fortune.
As of right now, which I haven't changed anything in about a week I have several things frozen/ uninstalled and my phone works great. Some things may very depending on what you use and don't use.
  • Apps 3.05.78
  • ChocoEUKor 1.0
  • Clock 1.0
  • Clock Digital 1.0
  • Clock Modern 1.0
  • Color 1.3.0.53-1
  • com.samsung.app.playreadyui
  • DirectShareManager 1.3.20
  • Downloads 4.0.4-I535VRALG7
  • Dual Clock (Digital) 1.0
  • Email 4.0
  • Enterprise VPN Services 4.0.4-I535VRALG7
  • Face Unlock 4.0.4-390215
  • FWUpgrade 1.2.0
  • Gmail 4.1.2
  • Google Bookmark Sync 4.0.4-390215
  • Google Calendar Sync 4.0.4-390215
  • Google Play Movies & TV 2.0.21
  • Google Play Music 4.3.609.436083
  • Google Search 1.0
  • Google Search 1.4.1.396604
  • Google Text-to-Speech Engine 4.0.4-390215
  • Guided Tours 2.1
  • Helv Neue S 1.0
  • HTML Viewer 4.0.4-I535VRALG7
  • Kies Air 2.1.20951
  • License Settings 1.10
  • Live Wallpaper Picker 4.0.4-I535VRALG7
  • Luminous Dots 1.0
  • Maps 6.12.0
  • MAPServiceSamsung 4.0.4-I535VRALG7
  • Media Hub 1.6.0
I'll add the rest later, I have some other things to do. Again, these are safe to freeze depending on what you use.
Addition 1:
Okay, I'll finish adding my list.
  • Music Hub 30.2012.09.11.17
  • Music Player 5.0.5
  • MusicFX 1.4
  • My Verizon Mobile 10.0.332
  • My Verizon Profile 0.2
  • Phase Beam 1.0
  • Photo Wall 1.0
  • PickupTutorial 4.0.4-I535VRALG7
  • Polaris Viewer 4.0 4.0.4024.27
  • RoseEUKor 1.0
  • S Memo 12.02.07.4816
  • S Suggest 3.1.69
  • S Voice 4.1.1
  • Samsung Account 1.2.086
  • Samsung Push Services 1.0.5
  • Samsung TTS
  • Setup Wizard 1.0
  • SIM Toolkit 4.0.4-I535VRALG7
  • SNS 1.01
  • Street View 1.8.1.0
  • Talk 4.0.4-I535VRALG7
  • Task Manager 1.0
  • Topic Wall 1.0
  • Trim 13.6.ms_hw
  • Verizon Tones 5.1
  • Voice Recorder 0.1
  • Voice Search 3.0.1
  • VPN Client 2.5.1
  • VZ Navigator 8.0.1.185
  • VZ Navigator 8.0.1.183
  • Weather 120605.02
  • Weather Daemon 12026.01
  • Weather Main 120605.02
  • Windy Weather 1.0
  • wssyncmlnps 2.0.0
  • Yahoo Finance 120510.01
  • Yahoo News 12.05.01.01
  • YouTube 4.1.23
This is all I've got right now. I don't know the most about all this stuff but I research many sites looking for the lists and combine what I find useful.
Hi, I think that I've frozen wrong apps in my Samsung GS3. As the result, I can't access any application.
My home screen is totally black, but all of other functions (incoming call or msg, wifi setting, etc) are still working well.
How do I fix this up? I could't find the way to launch my Titanium Backup too.
Many thx before..
  • Apps 3.05.78
  • ChocoEUKor 1.0
  • Clock 1.0
  • Clock Digital 1.0
  • Clock Modern 1.0
  • Color 1.3.0.53-1
  • Email 4.0
  • FWUpgrade 1.2.0
  • Gmail 4.1.2
  • Google Search 1.0
  • Guided Tours 2.1
  • Helv Neue S 1.0
  • Luminous Dots 1.0
  • Maps 6.12.0
  • Media Hub 1.6.0
Addition 1:
  • MusicFX 1.4
  • Phase Beam 1.0
  • Photo Wall 1.0
  • RoseEUKor 1.0
  • S Suggest 3.1.69
  • S Voice 4.1.1
  • Samsung TTS
  • Setup Wizard 1.0
  • SNS 1.01
  • Task Manager 1.0
  • Topic Wall 1.0
  • Trim 13.6.ms_hw
  • Verizon Tones 5.1
  • VPN Client 2.5.1
  • Weather 120605.02
  • Windy Weather 1.0
  • wssyncmlnps 2.0.0
  • YouTube 4.1.23
Thanks, I will add these to the list. Been without cable because of Hurricane Sandy and just getting caught up on everything now. Thanks for the update!
Many thx before..
Did you freeze the launcher? Is there a way you can provide us with a list of what you froze or disabled?
Kyle TW
