- Feb 9, 2011
- 20
- 10
- 0
If followed correctly, this a bulletproof method (reposted from our work at Rootzwiki) of returning any image to a true 5.5.886 stock and then applying the OTA update.
Commands/Screenshots
Credit to all developers of the zergRush exploit, to realbbb (from Rootswiki) for discovering the Boot Mod, and anyone else who participated in making this all possible.
- Moto-Fastboot Commands
- Root Commands
- Boot Mod Commands
- ***All the files you must have in one folder - Full Package from below***
- Motorola Drivers v5.4.0 (32-bit) or Motorola Drivers v5.4.0 (64-bit)
- 5.5.886 Radios (radio.zip)
- Full Package of All Other Files You Will Need: Link 1 or Link 2 or Link 3
- 5.5.886 Boot Mod
- 5.5.886 FXZ Restore File
- Motorola Fastboot
- Root and Forever Root Files
- ADB-Fastboot Files
- 5.5.893 OTA Update
- RSDLite v5.6
- Make sure the phone is off
- Hold down the Volume Down + Volume Up buttons and press the Power button
- When the choices appears, press Volume Down twice, till "AP Fastboot" is selected
- Press Volume Up to select
- When the choices appears, press Volume Down once, till "Recovery" is selected
- When the icon with the android and exclamation appear press both Volume Up and Volume Down at the same time to enter the recovery
- Download the 3 files under "Necessary Resources"
- Install the appropriate Motorola drivers for your operating system
- Place the radio.zip file on the root of your SD card (not internal storage)
- Unpack the full package of files to one folder on your computer
- Turn off your phone completely
- Start into Fastboot Mode (listed above)
- Connect your phone to your PC with the USB cable and let it install the drivers for your device
- After the drivers are done installing, open a command prompt in the folder where you unzipped the full package to
- Using the Moto-Fastboot Commands screenshot from above follow each one step by step until you are done
- When you have finished, disconnect your USB cable and press the Power button once to turn it off
- Start into Recovery Mode (listed above)
- Highlight "wipe cache partition" and press the Power button to select it
- When it has completed, pull the battery out of your phone and then put it back in
- Start into Recovery Mode again
- Highlight "apply update from sdcard" and press the Power button to select it
- Highlight the "radio.zip" file on your SD card and press the Power button to select it
- When it has completed, highlight "reboot system now" and press the Power button to select it
- When the device reboots into the OS waited 1 minute for it to load everything in the background
- Follow the prompt but don't sign into anything, just get to the homescreen
- When at the homescreen, connect your USB cable and then from the pull down menu select "USB connection", then select "Charge Only" and hit OK
- Go into Settings -> Applications and enable Unknown Sources and hit OK
- Go into Development and enable USB Debugging and hit OK
- Back out to Settings -> Battery & data manager -> Battery mode and select Performance mode
- Power off your phone and then power it back on normally
- Open a command prompt in the folder where you unzipped the full package to
- Using the Root Commands screenshot from above follow each one step by step until you are done
- Using the Boot Mod Commands screenshot from above follow each one step by step until you are done
- ***When a Superuser prompt appears on your phone after the last command, quickly select Allow and make sure you do NOT reboot your phone***
- When it has finished, connect your phone to your 3G/4G or a WiFi connection
- Go into Settings -> About phone and select System updates
- When the prompt comes up, press Setup
- Place a check in "I agree to the Motorola Terms of Service" and then press Next
- When the update prompt comes up, press Download
- Wait for the update to download
- When the update prompt comes up, press Install Now
- Let update reboot to recovery and install itself
- ***Your phone may appear as if it is completely off for a little while but leave it be it will turn itself on and continue***
- Let the update finish and then it will reboot back into your system
- Congratulations! You now have the official 5.5.893 update installed and are back on the official OTA path and forever rooted
