[GUIDE] Jellybean, Flash, Dolphin Browser with pinch zoom working
fireplug
58
Not certain if this is the only way to get the latest versions of Dolphin Browser, Adobe Flash Player and Jellybean to play nice together, but this is a method that worked for me.
With this method I believe that you must choose between Always On or On Demand in Dolphin, because I think the software only limits your ability to make changes to the Flash setting, and since the default is normally Off when one downloads from the play store, normally one can't activate Flash without getting the slap on the hand "you can't do that" from Dolphin. The trick here is to save a copy of the Dolphin ICS settings which allow Flash use and then restore those on JB.
This is how it worked for me.
You need:
1. A device running ICS which probably needs to be rooted.
2. Your device running Jellybean which probably needs to be rooted.
3. Titanium backup on both device
4. A version of the Flash Player apk to side load which you can download (they are still available if you Google search) or a Titanium backed up version that you already made.
Turn off automatic backup from your Google account on your JB device.
On your ICS device install Titanium backup and Dolphin from the market. Open Dolphin, go to settings and turn on Flash content. Exit Dolphin. Open Titanium backup and make a backup of Dolphin and Flash player if that is how you will be getting Flash. Now you need to copy those backup files to your Jellybean device. There are several ways to do so which I won't cover here.
On your Jellybean device uninstall any copies of Dolphin and Flash you may already have on there. You can backup your bookmarks first if you wish but can't do a full backup and restore of all your settings because they will overwrite what we are going to do. Now, with a clean Jellybean, install titanium backup from the market if you don't already have it. Open titanium backup and find that dolphin backup you moved from the ICS device. Restore the app and data. Open Dolphin and go to settings and see that Flash is enabled but don't touch the toggle. Close Dolphin. Now either restore the Flash app in Titanium, or install it from an apk you found on the net
That's it.
Open Dolphin and you should now be able to use Flash, and pinch zoom.
Never touch the flash toggle in Dolphin, and I wouldn't let Dolphin update either.
Your milage may vary, but this worked for me. "Thanks" are appreciated if this works for you.:)
Good luck and please excuse any typos or mistakes as I was typing this in the car as my daughter was driving (scary)
UPDATE: This method works for Dolphin Beta Browser as well which has improved HTML5 compatibility.
pututo
