[GUIDE] LauncherPro Ice Cream Sandwich how-to [UPDATED 10/19]
Batting1000
314
68
Hello and welcome to my guide on how to theme LauncherPro so that it looks like Ice Cream Sandwich, the newest and best looking version of the Android OS.
DISCLAIMER: I take no credit for any icons, launchers, pictures, or anything else used in this guide. Everything belongs to their respective owners.
Before we begin, here are some things that you will need to download:
1. LauncherPro, the free version or the paid version will work just fine (this guide is intended for use on LauncherPro. I have not tested it on any other launcher)
2. Desktop Visualizer - Click here to download it for free from the Android Market
3. Download these Android 4.0 icons, extracted from the SDK by l0st.prophet. Images by Google.
4. Download the Android 4.0 clock widget for FREE here: https://market.android.com/details?id=com.icecreamsandwichclock.clock (Credit to developer juliojs) (This is optional)
5. Download the Google Search Widget image and App drawer icon at the bottom of this post. Add them to the folder of Android 4.0 icons to access them easier.
6. Download the dock background here: http://img684.imageshack.us/img684/928/hhhha.png
Add the folder(s) of images to the first level of your SD card / USB storage.
Steps:
Step 1: From your homescreen (while in LauncherPro), hit Menu, click Preferences, then click Appearance Settings. Choose Dock Background and choose Gallery if you are asked. Browse to the dock background linked above.
Step 2: Go back into the LauncherPro Preferences and restart the launcher. Your dock background should now have a white strip above the icons on your dock.
Step 3: Next, go to Preferences (by hitting Menu), choose Dock Settings, and then click Number of Docks. Set this to 1.
Step 4: On the homescreen, hold down on the 1st icon of the dock. Change it to the Phone app and when you get the popup to change the icon and name, change the icon to the Android 4.0 Phone icon, the big blue phone.
Step 5: Change the second dock icon to your Contacts application. Again, change the icon to the Android 4.0 Contacts icon.
Step 6: Now, the app drawer icon. Make sure the middle shortcut leads you to your app drawer. Hold down on the icon and click Change Icon, then click Custom icon. Browse to the proved app drawer icon.
Step 7: Change the 4th dock icon to your Messages application. Change its icon to the provided Android 4.0 Messages icon.
Step 8: Change the 5th dock icon to your Browser application. Change its icon to the provided Android 4.0 Browser icon.
Your dock should now look like this:
After you complete the dock, feel free to change more icons on your homescreen or change the dock to whatever you'd like. The above is only an example. Please note that this guide will not affect the look of your app drawer icons, only the icons you change on your homescreen. To change non-dock icons, remove the icon from the screen. Then, hold down on the screen, click Shortcuts, Applications, then choose the app. You then get the option to change the icon and name.
Now, lets set up the Google Search widget.
Step 9: Add a widget on your homescreen for "Desktop Visualizer 4x1" and click the box that shows up on your homescreen. When the options for the widget pop up, choose the icon button and browse to where you put the search widget icon. Choose the search widget icon. Make the "Select Action" launch the Google Search widget. Click the clear button next to "Label" and make the touch effect "None" and add the widget to the homescreen. (Download the Google Search widget picture from the bottom of this post)
Step 10: Add the Ice Cream Sandwich clock to your homescreen (optional).
Step 11: Go to Menu --> Preferences --> Appearance and uncheck "Show icon labels background". Restart the launcher.
Here's an example of what I did to my homescreen:
Step 12: Back up your homescreen settings and layout in the LauncherPro settings. The theming is now complete. :)
For an added ICS look, you can get the wallpapers from ICS by visiting the following link and downloading the wallpapers, courtesy of Android Police / P3Droid. Also, add other icons to your homescreen and change their icons to the Android 4.0 ones. Also, to change the icon of the app, you'll need to remove the icon from the homescreen, then when you re-add it, it lets you change the icon. Please note, this will not change the app drawer icons, only ones you CHOOSE to change on the homescreen and dock.
For the ICS lockscreen clock, check out this thread by xaffron: http://forum.xda-developers.com/showthread.php?t=1310766
http://www.androidpolice.com/2011/1...xusnexus-prime-ice-cream-sandwich-wallpapers/
If you have any questions or need help, post here to let me know. :)
Um I have managed to do everything but I downloaded all the stuff you said to. But I cannot find the app drawer icon or the google search one.
I ended up having to download the search skin and app draw icon seperately but thanks. My epic 4g looks so cool now.
Hey guys
Sorry for not replying. I have been busy. I'm also sorry for not including the search widget and app drawer icon. Give me a few minutes and ill get them up. Forgot to attach them when I copied my thread over from XDA to here.
Sent from my Nexus S 4G using Tapatalk
Nope, works without root too. Just download LauncherPro from the market and follow the steps. :)
EDIT: Ok, just added in the search widget and app button!
When I go to choose the icon it will not let me and the icon itself isn't showing up right in the folder. Just wondering if its just me? I will download again and see what happens....
Mez, just gather all the icons and get them in the same folder. Also, make sure that folder is on the first level of your SDcard.
thanks for adding the search bar. i was debating about not using it since it wasnt in the package and i dont use it often but since its right infront of me there's no excuse and it doesnt look quite right with my vlingo bar in its place
No problem. It's my fault. I forgot to attach it to the thread when I copied the XDA version I made over.
