(GUIDE) MR1 Restore for insurance from GB 2.11.605.0 Signed RUU
wildman
2,158
230
UPDATE METHOD: This was pulled from another site that isnt my work but it works as well so I decided to post it with my method to give you a choice of methods....
Links:
Driver
http://downloads.unrevoked.com/HTCDriver3.0.0.007.exe
Guide
http://www.thunderboltforums.com/for...nary-root.html
_______________________________________________________________________________________________________________________
My Method..
I have notice a number of users asking for a method to restore to a Stock MR1 state after installing the Leak build of 2.11.605.0 GB RUU after rooting with Revolution exploit and there wasn’t any informational post to get a user back to a stock state or for insurance return..
This process isnt as simple as just flashing the PG05IMG_Mecha_VERIZON_WWE_1.66.605.2_Radio_1.39.00.0510w_NV_8k_1.41_9k_1.64_release_191132_signed like some believe because unrooted older RUU can not be installed over newer builds without being rooting. also this appears to not restore the device to a S-On state to be able to return the device to a stock state to return for warranty and Revolution has no unroot process as of this day.
The Bootloader will still have the Revolution bootloader with the S-Off status and the method used to restore the stock bootloader with MR2 patch sometimes can not override the loader because it is a newer build and used a different exploit method, so when this is attempted it simply skips the installation process and ask to reboot the device.
Ok with all that said here is all that is needed and the steps to get you back to Stock from using 2.11.506.0 GB RUU rooted because unrooted a downgrade doesn’t appear possible at this time.
UNINSTALL HTC SYNC BEFORE PROCEEDING FEATURE.
1. Run Revolution - Revolutionary
(Remember to complete form for Beta Key).
2. Follow instructions exact (Its Painless)
The last step ask to install Revolution Recover (Allow this by saying YES), this will place a su_2.3.6.3_efgh_signed.zip on sd card root (If file doesnt show you can download it from http://goo-inside.me/superuser/su-2.3.6.3-efgh-signed.zip) and place file on sd card root..
After completing and getting S-Off access proceed to set #3
3. Power off device and then power into bootloader (Volume Down and Power until white bootloader screen)
• Select Bootloader / Recovey(Up and Down arrows to select and power to enter)
• Once in installation select Install zip for SD Card / choose zip from card/su_2.3.6.3_efgh_signed.zip
There should be a SuperUser (Skull icon) on the launcher menu to indicate rooted..
Once booted up completes, unlock your screen to enter the setup wizard.
• Hit Next > Skip > Skip Setup > Next > Next > Next > Finish
• Then hit the menu capacitive button > settings > applications > development > check USB debugging > then click Ok.
• Plug the Thunderbolt into your computer.
• Swipe down on notification panel.
• You will see "Charge Only: Select to change USB connection type" --> press it.
• Select “Disk Drive” and then click Done.
4.Rename to PG05IMG and Copy this PG05IMG_Mecha_VERIZON_WWE_1.66.605.2_Radio_1.39.00.0510w_NV_8k_1.41_9k_1.64_release_191132_signed.zip to SD Card root.
• Select Bootloader / Fastboot (Up and Down arrows to select and power to enter)
• Install zip and restart when prompted on device..
• Select Charge Only and then click Done.
5. Download Auto Root MR1 Downgrade and Root Process downloaded from http://forums.androidcentral.com/th...unroot-windows-updated-5-20-w-mr1-update.html
6. Run the Auto Root MR1 Downgrade and Root Process downloaded from PC and follow instructions exactly.
IMPORTANT NOTE: Device is already rooted with Revolutionary but when you are prompted to "Start root after downgrade" you have to say YES to allow the installation to remove Revolutionary hboot and roll hboot back to stock.
7. After completing Auto Root MR1 Downgrade and Root Process and boot up completes, unlock your screen to enter the setup wizard.
If you just wanted to restore to stock state with rooted version of MR1 you are complete.. If you want to restore the stock with root disabled for sending in for insurance proceed to step 1b below..
1a. Download PG05IMG_MR1_no_hboot.zip from [HOWTO] Restore to stock for root users and non-root users UPDATED 5/17/2011 - xda-developers
MD5: c64b4367086fff4f51ec3d5d766a0456
This will place a Storage device show under PC Computer area labeled "Removable Disk"
2a. Rename "PG05IMG_MR1_no_hboot.zip.zip" “PG05IMG.zip” and copy to SD Card
3a. Power off device and then power into bootloader (Volume Down and Power until white bootloader screen)
• Select Bootloader / fastboot (Up and Down arrows to select and power to enter)
• System will scan for PG05IMG.zip and once found move to next step.
• Option will ask if you want installation to start - Yes (Up) or No (Down)
• Press Up to start update
• Allow process to complete and wait for option to show “Boot Device”
4a. Download PG05IMG_hboot_1.4.0000.zip from [HOWTO] Restore to stock for root users and non-root users UPDATED 5/17/2011 - xda-developers
MD5: abda920f3e159fb05c00d8c54a5b8768
• Select “Storage Disk” and then click Done.
5a. Rename "PG05IMG_hboot_1.4.0000.zip" “PG05IMG.zip” and copy to SD Card
6a. Power off device and then power into bootloader (Volume Down and Power until white bootloader screen)
• Press Power button to reboot
• ALL DONE
Now you should have a unrooted STOCK HTC Thunderbolt and ready for insurance claim….
If experiencing activation issues after this process you need to flash a Froyo radio and then phone will activate fine..
This is the method that worked for me and I hope it is helpful for others..
ALL INFORMATION IS FROM MEMORY SO IF ANY MISTAKES WAS MADE PM ME AND I WILL LOOK TO UPDATE..
Bond32
1,358
35
Re: (GUIDE) MR1 Restore for insurance from GB 2.11.605.0 Signed R
Excellent write up. I'm sure this will help a lot of people out. Thanks
ksheth2130
59
6
Thanks for the write up! I actually just did everything step by step and went back to MR1, then got the software update for MR2. But I have a question about the Hboot screen. When I get into Hboot, the top shows that it is the Hboot from Revolutionary. Is there a way to get back to the original Hboot by HTC/Verizon; or does it even matter?
Bond32
1,358
35
Sounds like you skipped step 4a and 5a.
ksheth2130
59
6
When I do step 5a and it reads the bootloader, this is what i get:
Parsing...[SD ZIP]
[1] BOOTLAODER - Bypassed
Update Complete...
Press <POWER> to reboot.
Once rebooted and I decide to go back into Hboot, I see the -Revolutionary- banner at the top still.
wildman
2,158
230
Parsing...[SD ZIP]
Update Complete...
Actually after step 5 it should have removed the Revolution HBoot, did you say no to the option to root device after download instead of "YES" because no wont update hboot but yes option is when the system updates the HBoot back to stock..
You have to be on Stock hboot for the last steps to work.
Repeat from step 5 and make sure to allow root after downgrade, I believe you can select option 2 without starting from beginning...
* If this is your first time rooting your ThunderBolt please start
from the beginning
* If for some reason you have started the rooting process and
were interupted by a fault or any other reason please start at
the appropriate point.
* If you do not know what to do visit us at AndroidCentral.com
1. Start root from beginning
2. Start root from after downgrade
Please update on if this worked for you..
fdisker
127
9
Parsing...[SD ZIP]
Update Complete...
Same thing happened to me. I had to follow the instructions in this thread to get back to the stock bootloader and S-OFF.
Brwnohno1
