Has any had issues with their Verizon Galaxy S4 on TMobile with Lollipop issues?
Goodeye
186
Verizon Galaxy S4 on Tmobile Lollipop issues
Just like the title says. I'm having issues with a Verizon Galaxy S4 which is unlocked and being used on T-Mobile. LTE and voice and data all seem to work fine after the Lollipop update. However, even with all the APN settings set for T-Mobile it won't send any SMS or MMS messages.
Anyone else had this issue or knows what to do next?
Re: Verizon Galaxy S4 on Tmobile Lollipop issues
Yep. It seems I can receive but not send at all. Gone through all the settings I can find but nothing seems to work. Worked fine before the lollipop upgrade.
Done two factory resets as well and nothing.
Happened to me as well I contacted Samsung and T-Mobile they say I need to change message center number but they took away that option in the messages settings so idk what we can do I've had a useless phone for weeks now :(
Have you figured it out? I just moved to Germany and had a Verizon Galaxy s5. The Telekom (t-mobile) sim card works after configuring the APN but I'm unable to send SMS. Wondering if you have figured out a solution.
gracie t
