- Mar 24, 2011
- 29
- 0
- 0
I'm in the hunt for the low power consumption in standby. My HD2 is using approx 2-10 mAh in standby normally (approx 5-10 mAh with HSDPA network in Europe) while my Thunderbolt is using 34-38 mAh on the 4G network.
I suspect that the 4G is the power drainer here but I'm waiting for a widget switching option (like a 4G switch on SwitchPro) before I turn it off when not needed. But the question is:
What is the lowest standby consumption the Thunderbolt can provide?
My target is to get down to atleast 10 mAh when the screen is off. But I'm not close to it despite power saving measures including underclocking with SetCPU.
I am using CurrentWidget to measure the consumption.
The 8650 CPU in the Thunderbolt should have lower consumption than the 8250 used in HD2.
On the other hand the Thunderbolt has much lower consumption (50-60 mAh) when I play music with PowerAMP with screen off compared to the HD2 (99-109 mAh in the same scenario).
