Have Samsung S7 Edge ANT+ ?
stonefox
24
If "Yes" - how can I connect between phone and ANT+ device ?
Yes. And depends on what your connecting?
Ooh I'd be interested to know if you can synch Garmin devices direct to the app using built in ant+. Would be nice not to have to use the computer. Might be another reason to buy the edge!
You can only sync certified. Things.
I use ANT+ to sync with my Tanita scale, and I plan to get the ibike app to sync with my bike sensor and Garmin heart rate strap. Both ibike and wahoo have a list of supported apps for their bike apps.
yayaaaa
