- Jan 22, 2014
- 17
- 0
- 0
Ok I found a simple way maybe to fix the charging on s3 note. The 2 prongs get bent down. So the charger slips over them I bent them back up with a knife and it's fine now. My symptoms where slow charging Couldn't move my phone with out it stop charging. And it would still die when it was charging. So on the bottom your phone there two prongs you need to look at them and see if they are bent down too far most likely is caused by you shoving the charger in upside down after about mine up my phone charges super fast with no more problems of me moving it and it disconnected from the charger over and over and over and over and over and over and over and over and over and over and over and over again
