A AC Question Dec 7, 2015 #1 Having problems assigning ringtones to contacts with droid turbo 2 In the contacts info it shows no ringtones anywhere
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,602 9,503 113 Dec 9, 2015 #2 Re: Having problems assigning ringtones to contacts with droid turbo 2 Welcome to Android Central! In the Contacts app, if you select a contact, then tap the Menu button, is there an option there to assign a ringtone?
X xxDeklinxx Active member Jul 19, 2012 35 1 0 Dec 23, 2015 #3 Re: Having problems assigning ringtones to contacts with droid turbo 2 Edit, then hit menu again. Has a Set Ringtone option
