Tom Gleeson Member Jun 18, 2013 7 0 0 May 18, 2018 #3 Start in apps and disable play services. Uninstall updates to play services and then reboot phone. Start a few apps and wait for one to require you to update play services. Once this has happened all should be well again.
orangecroc Trusted Member Nov 2, 2016 1,050 0 0 May 18, 2018 #4 Thanks man, problem solved! Spot on advice.
orangecroc Trusted Member Nov 2, 2016 1,050 0 0 May 18, 2018 #6 Just need to find out why three haven't pushed a single firmware update next.
rajeshr68 Well-known member Dec 1, 2011 206 0 0 May 18, 2018 #7 There is a new version of Play Services that fixes this - it's in Beta right now.
S shadowy Active member Sep 23, 2012 31 0 6 May 19, 2018 #8 I got an upgrade for my Three branded phone yesterday.
orangecroc Trusted Member Nov 2, 2016 1,050 0 0 May 19, 2018 #9 shadowy said: I got an upgrade for my Three branded phone yesterday. Click to expand... I got the .110 update this morning with the April security patch.
O OleKristoffer Member May 6, 2018 12 0 0 May 20, 2018 #10 I just deleted app data (not only buffer). Worked for me too.
