Having problems with group MMS
oelitreby
6
Never have had any issues with my HTC One group messaging when it was stock.
I rooted and then flashed GE ROM two nights ago. Yesterday had issues with group MMS. When I sent to a group of five, it would only go to two or three recipients. I received some group MMS messages that excluded someone on my end. Anyone else have issues with group MMS on GE?
Isn't the Google ROM a cyanogen mod ROM? If so there's your answer.
Sent from my HTCONE using Tapatalk 2
No, its not. I'm currently using GoSms, and while group messaging works, I hate GoSms. Wish I could use stock. Tried Textra, but I don't receive messages with it. Really not happy with this.
Sent from my HTC One GE using Tapatalk 4 Beta
I'm having the same issue. Did you find a fix?
No fix for stock messaging. Using Textra.
How is it working, and how is it compared to stock? Is there a way to turn off the stock messaging app after getting textra, or will it always be running (with the only option to turn off notifications)?
Works perfectly. Very lightweight. Just as good as stock IMO.
Not possible to turn off stock messaging. Turned off notifications and removed from my home screen, don't even notice it.
Great, thanks for the heads up!
Hey I'm using Textra now, and group messaging is still not working sadly. If you don't mind me asking, what are your APN settings?
Update: It's now working for me with Go SMS Pro. I hope it works with textra later on though. It is so much better mainly because it's a very simple and easy to use app.
Screwgoogle
