- Mar 14, 2012
- 141
- 0
- 0
Anyone else notice this and have a fix? On max volume its just moderately loud.
Really?
I just installed speakerboost and my volume is louder with the boost set at 0%. The app is dated 1st of September.
Suggest you pick up a pair of 'in ear' earphones which form a tight seal in the ear canal.The seal cuts out ambient noise quite effectively. You won't need an active noise cancelling earphone then.I have had the same issue. I was about to go on Amazon for a new pair of headphones for an upcoming trip when I saw this thread.
What kind of headphones are you guys using - in ear, on ear, noise canceling? I use a pair of Sony's that are really for the gym. The are "in-ear" but don't actually seal the ear canal - they just kind of rest in there. I was thinking of getting a pair that creates a tighter seal to eliminate surrounding noise. That or a pair of noise canceling headphones. Has anyone tried different types of headphones and if so what were the results?
