N Nightdiff Well-known member Oct 7, 2015 129 0 0 Jan 21, 2016 #1 Does anyone know a pair of headphones that work with mophie case without using stupid jack extender Posted via the Android Central App
itguyjax8430 Retired Moderator Mar 15, 2013 6,822 0 0 Jan 25, 2016 #2 I haven't seen any, you would think that Mophie would just make the hole bigger. You could try making the hole bigger. That is what I did on mine.
N Nightdiff Well-known member Oct 7, 2015 129 0 0 Jan 25, 2016 #3 itguyjax8430 said: I haven't seen any, you would think that Mophie would just make the hole bigger. You could try making the hole bigger. That is what I did on mine. Click to expand... How did u do that? Posted via the Android Central App
itguyjax8430 Retired Moderator Mar 15, 2013 6,822 0 0 Jan 26, 2016 #4 Nightdiff said: How did u do that? Posted via the Android Central App Click to expand... I used a drill bit a little bigger than the hole and went really slow.
N Nightdiff Well-known member Oct 7, 2015 129 0 0 Jan 26, 2016 #5 Wow really what size bit and what type Posted via the Android Central App
