Help a noob
zaro27
3
Ok, so I've got a rooted and unlocked Rezound and I want to get the OTA ICS. Any chance that I can unroot and relock or something? I've been able to pull the update, but it won't work. After running the second update, I get stuck at the white HTC screen. I've pulled the battery and reloaded it, but I think I'm a little in over my head.
I think I might try the S-OFF trick.
Dude I am in the same boat. We have to be completely stock and I am still waiting on a stock recovery to download...or at least a link...I have searched but...
This boat blows. It's all leaky and the buffet is nothing but tofu flavored tofu.
Relock and run the RUU. I'll find a link in a second and post more for ya both.
Do you want to be rooted after, or just stock?
Go HERE
You mush relock your phone, the command in ADB is "fastboot oem lock"
Download the file that looks like 3.14.605.12_ZIP this. The site it takes you to you have to wait 10 seconds, and then the download will start. After that file downloads, it must be moved the ext_sd card, and renamed PH98IMG.zip
If you run the RUU, you just ahve to be "relocked"
If you want to take the actual ota, you have to be relocked, unrooted, have stock recovery, and all of the stock apps have to be there and unfrozen. Basically 100% stock.
Sent from my ASUS Transformer Pad TF300T
Well I know one thing pizzadude (oh now I am hungry thanks to you), I will owe you a beer whenever I am in PA.
AyseDogan
