• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
HELP!! att i337 s4 phone calls not working well
canadiancrab
3
Hi all,
I have a galaxy s4 i337 from att. I unlocked it and am running it on simplemobile.. the phone cuts out mid calls, sometimes it doesnt dial out at all, when I answer sometimes the phone stays on the screen where you can either reject the call or accept it but doesnt actually do either.. this is becoming a major issue, to the point I wish I didnt give away my galaxy s2..at least that one functioned properly.
I also am still stuck on 4.2 version of android, and never got new versions pushed.. I really need my phone to work properly- im at the point where I just want to throw it at a wall whenever it gives me issues..
Ive also tried changing the gsm/cdma settings from lte/gsm auto to just gsm.. no luck..
Please help!!
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Hello. Sounds like a problem with the carrier. It could also be a APN issue.
Wizzrah | AT&T HTC One XL | Tapatalk
metle_geek
1,018
Yea I was thinking the same thing also are you sure simple mobile and at&t run the same gsm bands?? Also check your apn not all Sims automatically set them so if it's still in default at&t it's guaranteed to screw up unless they run the same bands and your going to have to change it anyway for mobile data
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
metle_geek
1,018
From what I can find on simple mobile.com you need to set your apn to a tmobile apn as they run off the t mobile network and your not going to get LTE as they are on the hspa+
metle_geek
1,018
Please do your research before switching
