- Oct 16, 2013
- 3
- 0
- 0
Hi All
First foray into the world of Android after finally handing in the work mobile.
I've had a play and all seems fine besides earlier I came across something that I did not set up and I can't seem to access since I disabled/removed. I also can;t seem to find this in the settings.
I have the security set to pattern, but when locked earlier the slide/swipe lock appeared with a slide left to lock, slide right to unlock and not sure if at the same time or once i slide to unlock 4-5 app icons to select from slightly above ( when i selected any it went to my regular lock screen "pattern") then continued with the selection. These were not widgets, but actual icons as you do if added to the homes screen when unlocked.
Any idea where this option is?
