- Aug 24, 2011
- 12
- 0
- 0
A local repair shop replaced the screen on my beloved G2. The screen peeled up the next day so I took it back under the 30 day warranty. The shop called and told me it is stuck in a boot loop. They said they can only get it to boot in Safe Mode (first I've heard of it). The shop is insisting they couldn't have messed up the software but the Android version now shows 4.2.2 and it was 4.1.whatever when I dropped it off. From the AT&T logo, it quickly shows the pattern screen and reboots. I was finally able to put my pattern in fast enough to arrive at the LG home screen (not my default). I disabled the pattern lock while I had the chance. It shows Safe Mode on the bottom left side and most of my apps are missing. I haven't rebooted again or done anything else yet.
What can I do to fix? Another forum said to uninstall the Xposed G2 app that came on mine and that fixed their device. I have no experience with flashing ROMs or doing recoveries on Android but I can follow instructions. Should I try another straight reboot? Should I uninstall the XPosed app and try to reboot? Should I factory reset? Some things seemed to indicate that could brick the thing at this point. I've never used ADB or done anything to hook it up to my MacBook. I'm afraid to do anything because I don't want to mess it up worse. Please help!!
Obviously, the repair shop isn't interesting in helping or I wouldn't be posting here.
