Help Help Help
Megan Porter
Hello Everyone!
I have a droid razr maxx and the battery life all the sudden wouldnt charge past like 20% and dioed so fast and the screen was going slower and not responding right sometimes. I work on my phone alot and it was driving me crazy, so I tried downloading battery enhancer and virus protection with spy ware.. and I feel like it got worse. So I went and some posts and how tos and I ended up trying to find the motorola task killer in my phone,,, well it took me a while but I thought I had found it and ran something, but after I did the phone is showing like processing words on the upper right and down the screen.? and it wasnt working right... Then it died because it always does anymore and I cant get it to turn on!!! PLEASE PLEASE ADVICE!!
Try a reboot by holding the power button, up and down volume keys at the same time for 10 seconds. It should reboot. If that doesn't work, you'll need to do a factory data reset.
Try a different charger.
Sent from my DROID RAZR using AC Forums mobile app
That doesn't sound good. Are you still unable to power it back on?
Try charging the phone for 24 hours straight, then hold the power button down for a good 20-30 seconds. As mentioned above, also try a different charger and charging cable. If it still isn't turning on, you might be out of luck.
KidColoringPage
