Help help!!
AndroidNote3
Active member
Dec 28, 2013
26
Guys my phones cpu is stuck at 2.2ghz and wont move, ive tried resetting the phone and ive unistalled the last app that I installed as it only happened when I put that app on my phone. Help please I dont want to have to fully wipe my phone.
The phone just feel blazing fast its like its on steroids and the cpu stats app just shows all cores running at 2.2ghz :(
Sent from my SM-N9005 using Tapatalk
You might have to just do a full reset...sorry 😔 hopefully someone can offer some advice
Hard to tell based on your information. Are you rooted? If you are, check your governor to see if it's set to performance.
Sent from my SM-N900V using Tapatalk
Nope im not rooted, I also have this problem where if I restart my phone and when I try to unlock it using the pattern it will only highlight 3 dots and then it wont do anymore, its hard to explain
It happened when I needed to update MyMagazing, I had to click on 'Unknown sources' to allow it to install and then literally straight after my phone become usain bolt?
vigorific
