- Feb 11, 2011
- 43
- 1
- 8
Hi all. New user here. Picked upan Epic Saturday. Unfortunaltly my first post has to be how to fix the thing. I had installed some software this morning (Batterie and Media Volume Plug-ins for Kit). Shortly after the phone crashed and went to a black screen with the LED notification light on and the virtual keys on the bottom lit. Pulling the battery lets the phone start up...it goes thorugh the Spring 4G thing, shows Galaxy S for a bit then goes to the state described above. If the think is plugged in and it is off I still get the battery charging screen.
I have tried reseting by holding the volume keys but I do not get the screens I have seen described (clear memory etc).
Any tips to get this thing back?
BTW, I have done none of the rooting or other hacking; just installed applications.
Thanks for any help!
