Help I bricked my LG VM701 Optimus Slider, how can I fix it?
  • Start date Start date
A
AC Question
I am in the process of porting my LG Optimus S VM701 from Virgin Mobile to RingPlus. I Rooted the phone, but was having a hard time changing the Phone Number to the RingPlus number. I got the correct instructions today, and change the number. To finich the process I tried to do a factory data reset. That put it in a Bootloop. I tried to apply a stock rom from the SD card, and now everytime I power the phone up, it unloads an Android package, restarts, goes to an LG screen and then goes blank. I can boot it in recovery mode and it will try to apply an update.zip file, but then it goes right in the same loop. Help, please.
Re: Help I bricked my LG VM701 Optimus Slider
This butchered thread is actually mine. I hope there is some solution, but I can't even boot the system into full recovery mode. I've made a bad situation even worse.
When I put it in Android Recovery Mode, it says: Check sdcard for GOTA update : /sdcard/update.zip
It also mentions apply /sdcard/update.zip via menu to proceed installation. - But I never get a menu.
Nehasingh12
