HELP! I think I bricked my phone...
adellc3
266
9
I tried flashing the DL30 update.
And it kept saying twlauncher was unresponsive when I rebooted, and now it just stays on the Samsung screen...
Idk what to do.. I'm flipping out.
can you battery pull and get into recovery?
it keeps saying something about twlauncher not responding and it has this really quick haptic feedback. Wut do?
id do it once more, if you keep getting these errors, id scrap and go back to DL09
maybe it was a bad download of DL30
it says
"The application TwLauncher(process com.sec.android.app.twlauncher) has stopped unexpectedly. Please try again.
Tell me that aint doo doo.
it says
Go into
Settings / Applications / Manage Applications select TW Launcher and click on Clear data.
Try that and then do a battery pull. Let us know if it works.
Okay, everything is fine now. I flashed DL09 again and then re-flashed DL30. Now its working, and I am rocking a sexy shiny froyo. Thanks so much for the help you guys.
Sent from my SCH-I500 using Tapatalk
have you tried superclean? it runs great.
If it's working fine and you're happy with it, I wouldn't touch it. That said all the Superclenas are in this subforum.
dparamoshkin
