- Dec 11, 2014
- 3
- 0
- 0
I was flashing a rom on my phone but it got bricked. I tried using a USB jig to put it in download mode but it wouldn't work on my s3 even though it worked on my friend's phone (same model). What should I do?
Are you able to boot into recovery? If you flashed the ROM, you should have made a backup through recovery. Once recovery loads you should be able to restore it once the backup is reloaded.I was flashing a rom on my phone but it got bricked. I tried using a USB jig to put it in download mode but it wouldn't work on my s3 even though it worked on my friend's phone (same model). What should I do?
That says "hardware failure" to me.I tried using a USB jig to put it in download mode but it wouldn't work
