Help ! Issues with 4.3 Upgrade
juicesrwild
4
Hello,
I'm from Toronto and had the 4.3 upgrade on my phone last week, probably Dec4-6. Since then my apps keep arbitrary opening, my music, my games, dialing pad.. its like my phone is on drugs! I'm frantically trying to close the apps only for others to open up simultaneously.
Also some of my apps stopped working and had to re-install them in order for them to work.
Anyone having issues? Anyone have any fixes or heard of any possible fixes available or in the future?
I have a note 2 with 4.3 update. My battery is fine, and the apps is normal.
I'm having trouble with my note 2. Ever since the update my phone freezes and i keep restarting it. Did the master reset , battery pull et all. Nothing is working. Any suggestions?
