Help me please... Nexus 4 update to Kit Kat error
ollwien
9
So I just got my OTA for 4.4 and downloaded the update. So I hit the restart and install button. The installing process ran like it supposed to be until the end part of it. The screen showed the word "error" with the android logo laying down. Then the phone just stayed like that and the screen not changing. So I decided to turn off the phone. Then I booted up the phone again, the google screen shows normally, but after that it shows the screen showing "no command" and I am stuck with that screen now and cannot go in. So I researched about it and find out I need to go to recovery mode. Then I hit the vol up and power button, then hit the recovery mode. But still, it shows the no command screen again.
Please help me... Thanks
I'm having the same problem, please help us!
---EDIT---
To get into recovery mode:
1) Press only the power button first
2) While holding the power button, press the vol up button for a couple of seconds
3) Let go ONLY of the vol up button, while still pressing the power button.
I already entered the recovery mode but still showing the "no command" screen. please help me :(
I also get the no command screen on the background, but I can choose wipe data, install updates and restart my phone, just use the Vol up-down.
The options that show up are start, restart bootloader, recovery mode, and power off. Then I picked the recovery mode, then the no command screen show up. How do you get to choose the option? I already hit the power vol up/down button, but the phone just boot up again. help me please :(
When you choose Recovery Mode and you get the no command screen do this:
bro, i manage to try the update using the image from here https://developers.google.com/android/nexus/images#occamkrt16s <--- nexus 4 kit kat. I chose the apply update from ADB but it shows signature verification failed. What should I do?
I tried the one on the video but i ended up with this... set_metadata_recursive: some changes failed E:Error in /tmp/update.zip (Status 7) Installation aborted
I also got an error with the 4.4 to 4.4.2 update when the OTA notification was given.
I later tried to sideload the zip file from the XDA OTA thread above, and it also gave me a signature error with an Mms file.
Seems like something is wrong with the OTA image?
sukarisw17
