- Oct 16, 2017
- 8
- 0
- 0
I've got a JVC stereo in my car and i'd like to make use of the MHL features so that i can use the sat nav through the screen on there with the S8. The stereo is a JVC-KW-V30BT
I've never used MHL at all and a few cables i've seen say they as an example " It does not support USB-C smartphones and tablets, for most of them work with with MHL solution or SlimPort solution instead of DP Alt mode"
Does anyone have an idea of what cable i need which might work ? uk based
Link to image for JVC Stereo installation: https://imgur.com/a/BDleN
