Question Help needed for Android Head Unit
sachin
3
I have chinese Head Unit with Allwinner T507 IC. All apps close after a few seconds. Android version is Android 10. The system also freezes sometimes. What is the solution to this? App Version is K2501_NWD_S212802.20220113.185227.01D.
Memory is 4GB Ram and 64GB ROM.
Welcome to Android Central! These no-name/off-brand Chinese head units are often plagued with software and hardware glitches, and have zero customer support. There may not be much you can do besides trying a factory reset.
Reactions: Laura Knotek
I merged your threads, since they're pretty much the same subject.
You may want to check the forums at XDA-Developers.com, which is a better resource for this kind of thing. But I'd say chances are low.
Ashok Dharshan
