help! not getting data signal
1moneymark
24
this my first attempt working with at&t phone. i rooted an older android version. to update i unrooted back to stock following skunkape's method. so now im on 4.1.1 so i rerooted the phone. phone works but now it dont get data connection. when i try to get on internet it says no signal found for mobil network. any suggestions? first mistake was not doing backup. any help is appriciated.
If all else fails you can flash the stock ROM via ODIN and get a fresh start.
data is on. what is apn settings?
here is what i have going on. this is an at&t gs3 on straight talk (ST). i rooted phone. was old version of android so i updated to 4.1.1. via stock rom in odin. now data dont work. i want to go back to ics to see if that helps. the stock ics i have is in .rar and wont run in odin. im not opposed to custom rom. i just need this to work
the mistake i made is not backing up before making changes.
No don't go back change the APN settings. Go to settings->more settings->mobile networks-> access point names-> click the plus button-> then put this.
Apn:tfdata
skip down to Mmsc
Mmsc:http://mms-tf.net
Mms proxy:mms3.tracfone.com
Mms port:80
alanmagdaong
