Help Not going into bootloader screen!
jmartellotta
5
All,
I recently just unlocked the bootloader and rooted my HOX. I found on this forum how to install the clockwork recovery mod. I did that and all went well, at least no errorrs. Now I was following instructions to download and install cleanrom LE. I copied the file to the phone and rebooted using the power and volume down. I got into the bootloader, and instead of hitting recovery, I hit factory reset.
Now my issues are I cannot get in the bootloader using the power and volume down. If I do run the command adb reboot bootloader and I able to get to the bootloader screen, but when I go to recovery, it just boots the phone backup. Any idea what I did and how to fix it?
Thanks a ton!!
J
I thought cleanrom was only for twrp?
Sent from my HTC One X using Android Central Forums
Nehasingh12
