Help! not sure what to do
Kabossa
Hi so I rooted and put on cyanogenmod 10 on my sgs3 a few days ago, the first day I noticed a worse battery life and now each day worse and worse things start happening. On top of the extremely quick draining battery the phone started not wanting to use the camera and would just freeze whenever a picture was taken, it refuses to connect to the network to use internet and wont connect to wifi either, and the time and date are going whack now. So I tried wiping the old rom off, doing a factory reset, and wiping the cache and reinstalled the rom and the patch for it and now the phone won't leave the samsung boot screen when I reboot it. Any help is appreciated.
So I managed to get back to where I was before the rebooting problem thanks to a backup but what should I do from this point to fix these problems?
What carrier/gapps and cm10 stable or a nightly also I recommend trwp recovery I've had issues in past and it works wonders for me......need extra help pme
Sent from my SGH-T999 using Tapatalk 2
Cm ROMs also include Liquid Smooth and Carbon (use CM as their base)
Find another ROM to flash. You can go back to the stock one, or try another custom one. Just be sure it's for the T-Mobile version of the phone.
collingsmwale8
