Help on finding inverted mms theme for carbon rom
truthfamilyfaith
121
I've downloaded the mod in xda for 4.2.2 messaging, but I get a failed install. I'm thinking it's not for 4.2.2 ROMs but to get that feel in another rom. Anyone know how and where to get an inverted mms 4.2.2 mod?
Like so much fonzy.
The problem is that Carbon is not deodexed. Use root explorer, (or something similar), to delete the odex file associated with the mms apk. Should work fine after that.
In order to use anything that's been themed you have to be on a deodexed ROM or delete the odex file of the themed app you're installing.
Sent from my Liquid GS3.
Also, how are you installing?
Do you have the link to the mms apk?
Edie Raleigh
