Help phone wont usb to computer
Wonderful! Could you describe your problem and the solution in detail so that it may help others? If not, perhaps consider deleting this thread.
Thank you.
my problem was that my phone wouldnt go into usb storage then i freaked out but i called my friend and he said do a factory reset
Again, I implore you to just delete this thread, as there is no useful information in it. Further, loosely suggesting a "factory reset" to resolve a USB connection error (usually related to Windoze driver issues) can be problematic for both stock and rooted users.
Thank you.
Thank you.
He can not delete this thread now since you responded to it, if I am not mistaken. Only a moderator can do that now.
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
witnessloc20
