Help Please, Am I still Rooted
travazz
I rooted my phone on June 16, a couple weeks ago. I had to factory reset my phone. Everything on the phone and memory card was erased other than Superuser Permissions. Superuser Permissions still shows up on my home screen.
Because SU is still there, am I still rooted? If so what do I need to put back on my memory card for everything to work properly?
I can't get into ADB Shell anymore either, I've tried all day and nothing has helped. I guess I got really lucky.
If I'm still rooted, is there an easier way to get into ADB Shell? Also if I am still rooted, how exactly to I do a NAND? And by doing this, will it make it easier to get into ADB Shell?
I know these are probably basic questions for some, but I would really like a little help to get a step in the right direction. I really appreciate anyone's help and knowledge on this.
ok well doing a factory reset does not unroot your phone. the reason why superuser.apk did not get erased is because it's under system/app and the rest of your daily use apps are under data/app. but to answer your question no. whenever one flashes a new ROM they should ALWAYS do a factory reset to make sure no old files don't mix well with new files. you should be able to get into adb shell. i don't quit get what you mean by you can't get into shell? even when not rooted one should be able to get into shell no problem. please clearify this a little more for me, i will be more then happy to assist you in getting you back up to where you want to be.
Borgey
I am still rooted. I'm at the XDA Custom Recovery and I'm having issues with it. Now I'm trying to follow the recovery steps and I'm having the following errors. Can anyone please help?
When I try to install the modified USB drivers I receive the following errors:
Error 0x80004005: Unspecified error on these specific dll files.
WdfCoInstaller01007.dll
WUDFUpdate_01007.dll
When I go to install the reflash-bundle, everything installs, but it fails installing the reflash.exe saying that the file is corrupt.
I'm using Windows 7 Ultimate x64, if that helps out
SeVeR
