Help please! How do I get iTunes on my Note 4?
Re: Help please!
I am surprised you have yet to be rescued. I have read many threads to accomplish this. Maybe you can run a search with those key words. If not, someone will come shortly I am sure. Good luck.
Re: Help please!
What I did I took 64gb sd card an copied all music on it but also some music won't play, so I've uploaded all the music to Google play and now it all works and you just download it, but I recommend uploading to Google play on Pc use program Music Manager, I'm sure you can find it on Google I found it pretty fast
Sent from my SAMSUNG-SM-N910A using Tapatalk
Re: Help please!
I just dragged and dropped from iTunes on to sd card
Re: Help please!
Yeah I opened my sd card, then opened iTunes selected all tracks and dragged them across to the sd card. All works fine on my note 4. I'm in the UK so not sure if iTunes works differently
iSyncr use to be my go-to software for transferring iTunes music to my Androids but for some reason I just couldn't get it to work with my Note 4. I tried DoubleTwist and that worked just fine. I like to use an app that keeps my playlists intact instead of dragging and dropping.
Couldn't tell you. Never used iTunes, never will use iTunes.
Thanks for answering his question in such a helpful manner. I am really glad that I now know that you have never, ever, ever used iTunes.
You cannot actually get iTunes on an android phone. You can get most of your music in a few ways. As some have said, you could just drag the music files to your phone or sd card. There are also a few apps that will let you transfer the music and playlists. iSyncr and Doubletwist are 2 that I can think of off the top of my head.
Of course there's always one in the group who blows stuff way out of proportion.
I finally got it by doing it through google play manager, however some of the albunm covers didnt go through.
