Help! Random icon appeared
Tpeg88
Yesterday I opened up my text messages and there was this red circle with something in the middle. It just appeared over night and I cant find how to remove it. Attached is a screen shot.
It's also on my recent calls but grey in there.
Did you enable multi-line settings or enrolled your number in DIGITS (if on T-Mobile)? That's the main line icon and shows up so you can tell which line the thread belongs to. If enabled (and don't want to disable it), you can also customize how that icon looks with different icon shapes and color options.
Just search for Mutli-line in your settings :)
If you never do a device maintenance + clearing ram, your device can shut down the ability to see apps to save resources if it becomes over loaded.
Thank you that worked! It just randomly appeared two days ago and was driving me nuts.
Dejesus54
