help setting up adb
jadenj5
73
im using windows 7 and cannot for the life of me figure out adb, i never used it on the hero, but with the optimus its the only option, i have the sdk installed, and all the device drivers. But when i try to do " adb devices" i get,
'adb' is not recognized as an internal or external command,
operable program or batch file.
i did edit the path, i think i did it correctly
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShel l\v1.0\;C:\Program Files (x86)\Common Files\Teleca Shared;C:\Program Files (x86)\QuickTime\QTSystem\;c:\android-sdk-windows\tools;c:\android-sdk-windows\platform-tools
thats what is is now.
will some one please helpppp mehhhh
You could try, in a dos window, cd'ing to the directory where you think adb is at and executing from there to enusre adb is functioning correctly.
This can be closed, issue was resolved, thank you all for suggestions
