Hey guys, so my DINC has been absolutely marvelous for the year I've had it running on CM7.2 but a week ago, it just randomly restarted and got itself into a boot loop.
The phone boots up and gets to the white Droid Incredible screen, and then turns off and repeats the process (almost indefinitely I assume, the longest I left it on like that was for half an hour after I got frustrated at it).
I CAN:
I CANNOT:
I've tried literally almost everything Google can throw at me, on two different batteries, and I'm at an end. Any help at all would be highly appreciated.
Running at the moment
I CAN:
- Boot into HBOOT and flash PB31IMG.zips
- Go into fastboot and find the device in command prompt
I CANNOT:
- Use any other feature of HBOOT (e.g. Recovery, Clear Storage, Factory Reset) as these just induce the boot loop
- Erase any partition using fastboot because it gives me a remote access error
- Use multiple RUU's (Froyo Stock ROM, GB ROM, etc) to flash a new rom; they all flash properly but the phone just boots back into it's boot loop
- Flash ROMs via PB31IMG.zip but it only produces the same effect as the RUU
- Flash a new recovery image but again it only reboots back into the boot loop
- Flash ENG HBOOT .72 and somehow manage to get into fastboot blindfolded because I have a SLCD screen and tried to erase partitions , but it still gave me a status malformed error
- Try to get S-ON but I can't use unrevokved seeing as how I can't enter my recovery
- Take it back to TWO different Verizon stores only to have them say both times that my phone is busted and push me to look at new ones.
Code:
INCREDIBLEC XD SHIP S-OFF
HBOOT-0.92.0000
MICROP-0417
TOUCH PANEL-ATELC03_16ac
RADIO-2.15.00.07.28
Jul 23 2010, 18:06:51
